Steam Issues after F41 Update
I’m experiencing a strange problem with Steam after the latest F41 update to Bazzite. It seems like there’s some sort of scaling issue - the Steam client is rendering way too small, and when I launch any game from Steam the game seems to be running at a massive resolution and I can only see the top quadrant of the game.
I tried running “ujust fix-reset-steam” and the client does re-install, but this error is displayed repeatedly in the terminal
ERROR: ld.so: object '/usr/lib/extest/libextest.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Anyone else seeing similar?
Similar. For me steam was always pretty small. I have a 4k screen with 175% scaling.
The update to 41 didn´t make it worse or better.
But stopping steam and starting it on command line with “steam” makes it workable.
Pretty strange.
Yea, scaling bugged and add a game menu doesn’t show
Edit: Just saw that happens also to battle.net and epic launcher running in bottles.
Edit 2: the problem is withing xwayland-native-scaling that was enabled in fedora 41 by default. Use only scale-monitor-framebuffer’ for now
gsettings set org.gnome.mutter experimental-features “[‘scale-monitor-framebuffer’]”
Thanks! That did the trick for me.
A note for noobs like me - I did have to modify the gsettings command for my setup. I’d recommend anyone finding this check their current config with
gsettings get org.gnome.mutter experimental-features
As an example, I utilize a VRR display so I had to include that feature in my set command:
gsettings set org.gnome.mutter experimental-features "['variable-refresh-rate', 'scale-monitor-framebuffer']"
