I was on the ublue kinoite spin and recently rebased on a wayblue one (hyprland). While on the former spin I used podman for almost everything I did. Now that I’ve rebased on the wayblue image I cannot attach to containers via podman. I can download images, and the containers I run actually start (I can see them with podman ps -a after they exit). Trying to run the container however fails. Here’s an example of what I’m seeing:
joe@oryp7-personal ~> podman ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
joe@oryp7-personal ~> podman run -ti hello-world
Resolved "hello-world" as an alias (/etc/containers/registries.conf.d/000-shortnames.conf)
Trying to pull quay.io/podman/hello:latest...
Getting image source signatures
Copying blob 83d537244900 done |
Copying config a4e07799a3 done |
Writing manifest to image destination
Error: OCI runtime error: crun: sd-bus call: Process org.freedesktop.systemd1 exited with status 1: Input/output error
joe@oryp7-personal ~ [126]> podman ps -a
421cb2d7062b quay.io/podman/hello:latest /usr/local/bin/po... 6 seconds ago Created exciting_zhukovsky
joe@oryp7-personal ~> podman run --detach hello-world
joe@oryp7-personal ~ [126]> podman run hello-world # No arguments
Does anyone have an idea of what this error means or how to fix it?
EDIT: Seems to be dbus related. If I switch to a TTY and run podman run hello-world it works fine. But if I do dbus-run-session podman run hello-world it fails like above.
Thanks!
