SDDM not starting if usb mouse connected
I’ve just replaced my mouse with a wireless usb dongle mouse, and now 9 times out of ten when starting my laptop, I get a black screen when SDDM normally shows the login gui. unplugging the mouse and restarting, then reconnecting the mouse after logging in works ok.
When the black screen occurs I can switch to another tty, and run sudo service sddm restart, and the login screen appears.
It seems to be related to the Black screen since latest update
I started the Black screen since latest update topic and still experience the issue.
I’m using a Logitech wireless mouse and keyboard combo. I just tested this by removing the logi bolt receiver from my PC before booting and it worked! I’m puzzled. Wondering what to do with this new information haha
I found a possible fix SDDM display manager fails to start · Issue #3376 · ublue-os/bazzite · GitHub
but I was unsure to try in case it breaks something now or later on.
Workaround (not a definitive fix): Random SDDM black screen – forcing X11 greeter
Note: I’m not claiming this is the root cause or the “official” solution.
This is simply a workaround that has been reliable for me.
Symptoms
  • Random black screen instead of SDDM login screen
  • Happens intermittently (often when USB mouse/keyboard is connected at boot)
  • Switching to a TTY and running systemctl restart sddm makes the login screen appear
  • Plasma Wayland works normally once logged in
Environment
  • Bazzite / Universal Blue
  • KDE Plasma
  • SDDM
  • Wayland sessions enabled
What worked for me (workaround)
I forced X11 only for the SDDM login screen, while keeping Wayland for Plasma sessions.
From a TTY or terminal:
sudo nano /etc/sddm.conf.d/20-x11-greeter.conf
Add:
[General]
DisplayServer=x11
Save the file, then restart SDDM:
sudo systemctl restart sddm
(or reboot)
Result (in my case)
  • SDDM login screen became stable
  • No more random black screens
  • USB devices no longer affected login
  • Plasma Wayland sessions continued to work normally
Notes
  • This does not disable Wayland system-wide
  • Only the SDDM greeter runs on X11
  • This seems to avoid a race condition between the SDDM Wayland greeter and USB/input initialization
How to undo
sudo rm /etc/sddm.conf.d/20-x11-greeter.conf
Again, this may not apply to everyone, but it’s been a solid workaround for me so far.
Thank you for sharing this link. I followed this comment SDDM display manager fails to start · Issue #3376 · ublue-os/bazzite · GitHub and the issue is finally resolved.
