Greetings,
after the last ujust update I had a black screen without cursor, both on build-in laptop screen and external monitor via hdmi. With Alt+Ctrl+F2 I got a prompt and could login.
With the help of Claude.ai I found out it is some issue with systemd-logind, with systemctl restart systemd-logind I could get to KDE Plasma. Claude gave me three very different approaches to have a semi-permanent fix.
That’s where my trust in AI ended and instead I just reinstalled Bazzite, but after running ujust update first thing after installation I had the same issue again.
Is this a known issue or something specific to my laptop?
bazzite:stable
Linux 6.17.5-ba07.fc43.x86_64
HP Laptop 17-ca1xxx
AMD Ryzen 3 3200U (4) @ 2.60 GHz
AMD Radeon Vega 3 Graphics [Integrated]
3.90 GiB / 13.56 GiB (29%)
KDE Plasma 6.4.5
KWin (Wayland)
Do you need me to get a specific protocol or run some other commands? I am just a linux casual user with no deeper insight into how it works but I can work with the terminal.
Any help is appriciated, I have been using Bazzite for 2 months now, and I would like to stay with it for a while.
cheers,
Anue
