RTL8125 network card speeds are capted
I finally took the plunge from Windows to Bazzite and am mostly happy, but one thing is driving me crazy. As I’m completely new to linux/bazzite I hope I can get some help or at least clarification from you guys and girls.
I got a B550 Aorus Pro AC motherboard with an RTL8125 network card. It is supposed to be able to handle 2.5 gb over Wifi as well as Ethernet, but I only get ~90-100mbps.
In my use case, I’ll be using the Ethernet connection, not wifi, but I have performed the tests below with both, getting the same results.
I’ve tried all of the troubleshooting I was able to find through Google and on Reddit, like in the network settings changing “Link Negotiation” to “Manual”, “Speed” to 1gb and “Metered” to No. Then a cold restart with powercycling. This caused the system to be unable to connect to the network at all, in a constant attempt to connect again.
When proceeding to sudo ethtool eno1 I get in the speed section “Speed: 100Mb/s”. Running sudo ethtool -s eno1 speed 1000 duplex full and then again sudo ethtool eno1 I was faced with a “Speed: Unknown!” and “Duplex: Unknown! (255)”. Through further research about the “Unknown!”, it seems as if the network card has no drives or the incorrect ones.
I confirmed that the card is recognised and installed through lspci -nnk | grep -i ethernet > which returned > “08:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)”.
To me, it looks like everything is properly installed, but when trying to increase the speed rage it looks like the system doesn’t understand that the hardware is capable of handling these speeds.
So now I have no further clue on how to proceed. I’m trying to make this my daily driver to get away from Windows, for good. But these network speeds make the system almost unusable for my main use, online games and work video calls.
Much appreciated any kind of insight into this, to at least understand it or how to solve it
Can you boot into a fedora live CD and do a test there that will narrow it down if this is specifically a universal blue image, problem, or a general fedora issue?
Hi there and thanks for your reply.
I just tested it with a live fedora cd and the same issue happens, the system registered the connection as a 100mbps
Yeah, that pretty much confirms it’s a Fedora issue. Fedora has a Discourse forum where you can post about this, and there’s also a Reddit forum where you can ask the same question. I’d check those first to see what other people are doing.
This may not be something you can fix yourself. It could also be that the particular Realtek network device isn’t well supported because the vendor hasn’t released enough documentation for the open-source drivers to work correctly. That said, I’m not sure.
Just for simplicity sake, have you tried a different cable and or a different port on your switch?
