On aurora-dx:latest
When I run rpm-ostree status I get this:
❯ rpm-ostree status
State: idle
Bus error (core dumped)
What is causing this?
It seems to be updating, but it’s nice to sse the output.
On aurora-dx:latest
❯ rpm-ostree status
State: idle
Never seen anything like this.
What do you get if you run rpm-ostree update?
Also are you on stable/stable-daily or latest image stream?
❯ rpm-ostree update
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:latest
No upgrade available.
I think it’s current at the moment. I am on latest image stream.
Oh sorry, you mentioned being on the latest image in the first post.
Atleast it looks that the whole rpm-ostree is not borked as seems it updates normally and doesn’t crash.
Does it give the same bland error if you do rpm-ostree status -v
Yes, same message…
The only remote idea I have is that I had a bad memory stick, I replaced it.
If I run a btrfs check I get errors, I need to boot to a USB stick to run it for the exact message.
~ btrfs check ~
root@localhost-live:~# btrfs check /dev/nvmexxxxx
Opening filesystem to check…
Checking filesystem on /dev/nvmexxxxx
UUID: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
[1/8] checking log skipped (none written)
[2/8] checking root items
[3/8] checking extents
ref mismatch on [509702152192 8192] extent item 140737488355329, found 1
ERROR: errors found in extent allocation tree or chunk allocation
[4/8] checking free space tree
[5/8] checking fs roots
unresolved ref dir 2859 index 516 namelen 67 name b9ecb9d1742bc4d80f86c73c175681e5f96de6adb3efe5306ee8e103a3ed43.file filetype 1 errors 4, no inode ref
unresolved ref dir 2859 index 516 namelen 67 name b9ecb9d1742bc�d80f86c73c175681e5f96de6adb3efe5306ee8e103a3ed43.file filetype 0 errors 3, no dir item, no dir index
ERROR: errors found in fs roots
found 663768059904 bytes used, error(s) found
total csum bytes: 202719488
total tree bytes: 2626912256
total fs tree bytes: 2178744320
total extent tree bytes: 204308480
btree space waste bytes: 560474952
file data blocks allocated: 1282914082816
referenced 683646259200
I am reluctant to run a repair because btrfs warns against it.
There are many btrfs forums that provide information on recovery but I have not had a lot of luck once the filesystem is corrupted. I don’t think there are many experts here that can help with that. I hope you have good luck trying to recover your disk.
I re-installed the OS, repairs were unsuccessful. No loss to files, the OS never crashed or anything.
