pixi provides the capabilities of brew and more.
It would be helpful to add pixi global sync to ujust update.
The following is copied from this link
Yes, pixi does exactly that. When you globally install a tool, you create individual environments for each tool, and we only expose the executables from the package that you are interested in. This is completely controllable via the “global manifest file”.
version = 1
[envs.coreutils]
channels = ["conda-forge"]
dependencies = { coreutils = "*" }
exposed = { tee = "tee", md5sum = "md5sum", split = "split", cat = "cat", shuf = "shuf", mkfifo = "mkfifo", pathchk = "pathchk", runcon = "runcon", expand = "expand", tty = "tty", basename = "basename", install = "install", nice = "nice", truncate = "truncate", echo = "echo", du = "du", ptx = "ptx", join = "join", pwd = "pwd", test = "test", csplit = "csplit", sort = "sort", whoami = "whoami", touch = "touch", unlink = "unlink", b2sum = "b2sum", sleep = "sleep", fmt = "fmt", stty = "stty", logname = "logname", chgrp = "chgrp", printenv = "printenv", seq = "seq", uname = "uname", sha224sum = "sha224sum", od = "od", date = "date", base64 = "base64", realpath = "realpath", readlink = "readlink", dircolors = "dircolors", timeout = "timeout", tac = "tac", numfmt = "numfmt", wc = "wc", basenc = "basenc", comm = "comm", nproc = "nproc", expr = "expr", cksum = "cksum", printf = "printf", groups = "groups", chcon = "chcon", factor = "factor", tail = "tail", env = "env", pr = "pr", head = "head", kill = "kill", uniq = "uniq", stat = "stat", link = "link", sum = "sum", tsort = "tsort", mknod = "mknod", users = "users", dd = "dd", who = "who", sha1sum = "sha1sum", mktemp = "mktemp", cut = "cut", sha256sum = "sha256sum", dir = "dir", mkdir = "mkdir", nl = "nl", shred = "shred", fold = "fold", rmdir = "rmdir", sha384sum = "sha384sum", mv = "mv", dirname = "dirname", id = "id", base32 = "base32", pinky = "pinky", ln = "ln", hostid = "hostid", chroot = "chroot", ls = "ls", true = "true", cp = "cp", sync = "sync", yes = "yes", unexpand = "unexpand", chown = "chown", chmod = "chmod", uptime = "uptime", rm = "rm", vdir = "vdir", false = "false", sha512sum = "sha512sum", "[" = "[", tr = "tr", paste = "paste", nohup = "nohup" }
[envs.git-lfs]
dependencies = { git-lfs = "*" }
exposed = { git-lfs = "git-lfs" }
You can modify the file by hand pixi global edit or use pixi global install foobar.
The exposed binaries can also be renamed - which allows you to install multiple versions side by side (for example, you could type exposed = { git-lfs-old = "git-lfs" }).
Unlike Homebrew, pixi (or really the conda ecosystem) also comes with a SAT solver and old versions are never deleted. That means you can still install python=3.5 or whatever.
Pixi also does not care where you put it on the PATH.
