Problems using Nvidia graphics cards
hello
I installed the operating system on my Asus laptop, but the problem is that games don’t use Nvidia’s graphics card!
They use the CPU graphics and I don’t know how to switch to Nvidia
My laptop has two graphics! Please advise me what to do.
Are you using secure boot? Presumably yes–if so did you enroll your mok? It would have been a prompt presented from your bios on the first reboot after installing bazzite.
My guess is that you just continued to boot rather than enrolling the mok, which prevents a bunch of kernel modules from loading. I believe there’s a ujust command to resolve it. I’ve not done this myself, so no promises, but try:
  1. Open up a terminal (ctrl + alt + t)
  2. run ujust (I think? I recall it being different on bazzite, I’m using Aurora atm, so for me it’s actually ujust-choose)
  3. select the option that looks something akin to “enroll-secure-boot-key” (again, I’m on Aurora so it might be named slightly differently)
  4. Reboot
If you’re asked for a secureboot password at some point I think it defaults to “ublue-os”
Generally you want to make sure you’ve followed all the steps here: Bazzite Inital Setup and Installation for General Desktop and Laptop Hardware
I’m afraid the problem hasn’t been solved.
I am facing the same issue. I will give it a shot and update here.
UPDATE: It worked :star_struck:
Here is the temporary solution which I found. Turn off the secure boot and boot the OS. Whenever you launch any app and you want to use your dedicated GPU just right-click and select “launch using discrete graphics card” (assuming you are on GNOME). Further, you can run “nvidia-smi” in the terminal it will show if your dedicated GPU is being used or not.
Had to change it on Lutris > Steam > System Options > Display > GPU
Took the chance to default it on every other thing on the Library just in case :slight_smile:
I recommend just setting up secure boot with the bazzite keys as it will be a set-it-and-forget-it solution to make sure the proper modules load and then you won’t have to mess with it further.
https://universal-blue.discourse.group/docs?topic=2742
Ah oops I meant this link.
