Hello.
Please help me understand what the problem is with installing Bazzite Os on Asus Rog Ally X? 4TB SSD. I do everything according to the instructions as it should be, but nothing works… Please help!
Bonjour, avez vous bien supprimer toute les partitions du disque dur avant d effectuer l’installation ?
I selected a disk space for bazzite os 200 gb, it is not defined.
6 partitions, two partitions for system recovery created by the system itself, the main space with windows 11, the partition that is allocated on bazzite os is not distributed, one. and already created by the system encrypted on 260 MB, and also created by the system on 4.61 GB is also not distributed.
While I generally don’t recommend dual-booting Bazzite if you’re installing it to a handheld, as having it as the main OS is the easiest option, there’s a guide for dual-booting here: Dual Boot Preliminary and Post-Installation Setup Guide - Bazzite Documentation
Thank you very much! You gave me an idea and I understood what the problem was! I had two unallocated partitions, I allocated one of them, which was 4.91 GB, and assigned it a volume and the installation started! Thank you!
