Opencode - Trust Me
If you run Linux/Bazzite, do yourself a favor and install Opencode. It literally can fix any Linux issue. Instead of spending hours trying to figure out issues, just prompt Opencode and it will go in and fix everything. It can interact with the OS so it can solve any OS issues right away.
It’s a MASSIVE time saver for Linux.
You could do the same thing with codex-cli or claude-cli or copilot terminal.
OpenCode requires you use API usage. Using codex-cli or claude you can use your regular subscription.
I would rather eat my own face than use any of this crap.
May as well just go install Microslop Winblows 11 and use Copepilot instead of Linux, Im here because of all this AI BS.
