Nvidia issue
I’m fairly new to linux and just installed bazzite on an all in one pc which has a mobile rtx2060 just to play some world of warcraft. Everything works fine out of the box however once i do a system update the nvidia x server settings app disappears and the nvidia card no longer shows up in wow’s graphics settings only the integrated gpu. Anyway to fix this or should i just not update the system after a fresh install?
can you run sudo bootc status and paste the response? Your GPU should be supported by both the open and closed source drivers. Is this a laptop with optimus?
I have the same issue. Unfortunately i didn’t find the solution to solve this problem without rollback.
Use rpm-ostree rollback in terminal and wait for update (ofc if update solve the problem)
yeah, i’m thinking it’s related to this: Black screen since latest update - #16 by ddawdler
Ahh I had this one as well. I lost the control panel after an update. Not been able to get it back. I did the bootc command and it says I have the open drivers. How do I get the closed drivers back?
