New to bazzite help
Hi ive just installed bazzite on my legion go.if i install a program where there an many versions EG
Windows
Mac
Linux
Am i right in thinking i need to install the linux version for bazzite
When younare talking about normal programs in Desktop mode than the best starting point is Discover. The software store for bazzite.
It pulls it’s software catalog from flathub.org
When there is not a fitting programm and you’re looking on the web the best option would be flatpak. The file format flathub uses!
Other formats can not easily installed on bazzite. Which is on purpose because it could interfere with other installed programs
But yes bazzite is a variant of Linux in the end
