this pops up every time in the terminal whenever i go to update I’ve tried to reinstall LACT to see if that was the error but it seems like a broken package. I’m up to date currently on this application 0.5.5 is the latest so any help to fix this issue would be appreciated.
Having the same issue as well. LACT is stuck on 0.5.4.
Trying to update LACT via ujust update seems to complete the update:
`ujust update` log
── 15:22:03 - Linux AMDGPU Control Application ─────────────────────────────────
Looking for updates…
Found upstream version v0.5.5, updating…
Installing LACT…
/tmp/lact.rpm 100% [==========================================================================================================================================================================================================>] 2.11M 13.04MB/s
[Files: 1 Bytes: 2.11M [1.82MB/s] Redirects: 1 Todo: 0 Errors: 0 ]
Inactive base replacements:
lact-0.5.5-0.x86_64
Checking out tree 079b615… done
Enabled rpm-md repositories: copr:copr.fedorainfracloud.org:matte-schwartz:sunshine copr:copr.fedorainfracloud.org:rodoma92:kde-cdemu-manager copr:copr.fedorainfracloud.org:rodoma92:rmlint copr:copr.fedorainfracloud.org:rok:cdemu fedora-cisco-openh264 updates fedora rpmfusion-free-updates-testing rpmfusion-free-updates rpmfusion-free updates-archive
Importing rpm-md… done
rpm-md repo ‘copr:copr.fedorainfracloud.org:matte-schwartz:sunshine’ (cached); generated: 2024-07-21T04:33:33Z solvables: 6
rpm-md repo ‘copr:copr.fedorainfracloud.org:rodoma92:kde-cdemu-manager’ (cached); generated: 2024-04-20T12:39:00Z solvables: 12
rpm-md repo ‘copr:copr.fedorainfracloud.org:rodoma92:rmlint’ (cached); generated: 2024-05-10T10:16:28Z solvables: 4
rpm-md repo ‘copr:copr.fedorainfracloud.org:rok:cdemu’ (cached); generated: 2024-07-09T09:13:21Z solvables: 23
rpm-md repo ‘fedora-cisco-openh264’ (cached); generated: 2024-03-12T11:45:42Z solvables: 3
rpm-md repo ‘updates’ (cached); generated: 2024-07-21T01:34:54Z solvables: 22000
rpm-md repo ‘fedora’ (cached); generated: 2024-04-14T18:51:11Z solvables: 74881
rpm-md repo ‘rpmfusion-free-updates-testing’ (cached); generated: 2024-07-19T11:40:41Z solvables: 16
rpm-md repo ‘rpmfusion-free-updates’ (cached); generated: 2024-07-21T01:22:54Z solvables: 136
rpm-md repo ‘rpmfusion-free’ (cached); generated: 2024-04-20T12:11:51Z solvables: 422
rpm-md repo ‘updates-archive’ (cached); generated: 2024-06-30T05:31:17Z solvables: 22869
Resolving dependencies… done
Checking out packages… done
Running pre scripts… done
Running post scripts… done
Running posttrans scripts… done
Writing rpmdb… done
Writing OSTree commit… done
Staging deployment… done
Freed: 137.6 MB (pkgcache branches: 0)
Use “rpm-ostree override reset” to undo overrides
Run “systemctl reboot” to start a reboot
Update complete
Running ujust update again LACT is still marked as “Inactive base replacements”.
Running ujust install-lact seems to fail:
`ujust install-lact` log
Installing LACT…
/tmp/lact.rpm 100% [==========================================================================================================================================================================================================>] 2.11M 10.91MB/s
[Files: 1 Bytes: 2.11M [1.77MB/s] Redirects: 1 Todo: 0 Errors: 0 ]
lact-0.5.5-0.x86_64
Problem: cannot install both lact-0.5.5-0.x86_64 from @commandline and lact-0.5.4-0.x86_64 from @commandline
- conflicting requests
With both methods, LACT is still at version 0.5.4.
Try this:
- uninstall LACT with
rpm-ostree uninstall lactand reboot - install LACT with
ujust install-lactand reboot
I don’t know if I tried that specifically I Will uninstall it and reinstall. I will let everyone know if it works.
That did install the new version of LACT, so thanks for the info!
However, the same version of LACT is still marked in “Inactive base replacements:”
I followed a discussion on the Fedora SIlverblue discourse and reset the LACT package using rpm-ostree override reset lact-0.5.5-0.x86_64
It seems to have worked and LACT 0.5.5 is no longer marked in “Inactive base replacements:”
yep that solved it thanks!
everything is fixed thanks guys it was really bugging me lol.
i like cohesion and it was out of place so it bothered me since i use the terminal a bunch but yeah thanks guys this thread will close soon but i appreciate the help and if i have any questions concerning issues with bazzite i will let everyone know.
