Hi, I’m testing out Bazzite on Aokzoe A1. From my understanding there should be a -aokzoe image available however i don’t see it anywhere. I used the -deck image instead.
So far it looks and works fine. However one thing I noticed is that the controller emulation from HHD stops working once you set the controller to sleep. I’m particularly more concerned with using the Home button for the Steam menu and the other button to open the quick menu. After restarting the device, it starts to work again. But when you put it to sleep and resume, it breaks again.
One other thing is performance degragation (FPS drop) once device wakes from sleep in certain games but I think this is common on many devices.
Any help would be greatly appreciated.
