Love Bazzite. Some questions around current issues
Bazzite has breathed new life into the Go for me and after much to’ing and fro’ing between the SD OLED and Go I feel like that is no longer an issue for me.
However after installing everything and tinkering to my liking I’ve found some very small QOL issues that I wanted to raise and see if they may be fixed in a later update:
  • Microphone not working. Interestingly I tested this out in an online voice recording website and it does seem to pick up my voice just not great quality
  • sleep/suspend. My current problem is for the first 1-2 seconds the controllers revert to controlling the OS rather than the game. In some games it actually tells me the controller has been disconnected for those 1-2 seconds but I think that’s just because the controllers are detachable and not sure that is fixable
Another fun thing that I’ve experienced is audio crackling. Have you experienced anything similar with the built-in speakers or via headphones?
I did experience this but the pause game decky plugin fixed this for me. Just need a fix for the remaining suspend issue I have and it’ll be a golden device!!
To be fair, this issue plagues SteamOS too, and only pause game plugin helps
Pause game works on Bazzite? I thought that plugin needed a swap file which Bazzite doesn’t use? Or did you create one?
I didn’t anything, plugin works
