Lutris refuses to start
Absolutely nothing visual happens when clicking on launcher icon.
Error logs:
$> flatpak run net.lutris.Lutris
F: Not sharing "/usr/share/icons" with sandbox: Path "/usr" is reserved by Flatpak
F: Not sharing "/usr/share/themes" with sandbox: Path "/usr" is reserved by Flatpak
2024-09-22 14:08:08,576: Starting Lutris 0.5.17
  File "/app/lib/python3.11/site-packages/lutris/gui/application.py", line 480, in do_command_line
    init_lutris()
  File "/app/lib/python3.11/site-packages/lutris/startup.py", line 133, in init_lutris
    init_dirs()
  File "/app/lib/python3.11/site-packages/lutris/startup.py", line 48, in init_dirs
    create_folder(directory)
  File "/app/lib/python3.11/site-packages/lutris/util/system.py", line 401, in create_folder
    os.makedirs(path, exist_ok=True)
  File "<frozen os>", line 215, in makedirs
  File "<frozen os>", line 225, in makedirs
OSError: [Errno 30] Read-only file system: '/home/user001/.var/app/net.lutris.Lutris/data/icons/hicolor/128x128'
2024-09-22 14:08:08,577: Shutting down Lutris
Obviously, everything inside /home is definitely not a read-only FS.
  • sudo chown -R $(whoami):$(id -ng) ~/.var/app/net.lutris.Lutris doesn’t help at all.
  • flatpak override --user --filesystem=home net.lutris.Lutris doesn’t help either
This is the flatpak, we pre-install Lutris as a native package. Please use that copy.
Everything worked on another machine, where I’ve rebased from Silverblue to Bazzite. Lutris was installed as a flatpak before rebasing.
On my current machine, where I’ve installed Bazzite from an ISO, I encountered this issue. For some reason, I didn’t have Lutris .desktop icon launcher after setup.
Lutris is pre-installed as an RPM in the image and the desktop definition is in /usr/share/applications. You can’t not have it under any circumstance. Remove the flatpak and run Lutris in a terminal if you don’t immediately see the desktop icon.
Yes, I verified it myself now. My confusion comes from not having a dedicated Lutris RPM .desktop launcher file. It was not present in the GNOME App menu, so I installed it as a flatpak.
I can confirm that file is present in a read only directory as part of the image. There is no way for that file to not exist on a bootable Bazzite install. It’s even added to the dash/task bar by default in both GNOME and KDE.
This is very strange. I can swear I was trying to run it from GNOME App menu, and it was not working no matter what…
And now it works.
Thank you anyway for the swift response.
So, there is something fishy going on with Lutris .desktop file.
When I search for it in search bar, I get launcher for RPM. When I look it up myself in the App menu, I get Flatpak.
Ok, for anyone having similar issues, do this:
#1. Remove Lutris flatpak
flatpak uninstall -y net.lutris.Lutris
#2. Remove Lutris flatpak .desktop file if it was not removed. It interferes with proper RPM one somehow, GNOME magic
rm ~/.local/share/applications/net.lutris.Lutris.desktop
#3. Log out & log in back, now you should have your proper Lutris launcher
