Low usage of system resources
Hi,
I switched to Bazzite last week from Windows and games have been running poorly.
When looking at the system monitor my GPU and CPU usage never go above 60% and temperature stays at around 55°C. Games also only use around 4gb of Ram, while Bazzite itself idles after startup at 5GB ram usage. This causes me to have low fps and frequent stutters. Ive looked on the web but havent found an issue similar to mine and any help is appreciated.
My rig is:
System Information
Operating System Bazzite
Kernel Linux 6.17.7-ba29.fc43.x86_64 x86_64
Model Micro-Star International Co., Ltd. MS-7C95
Motherboard Micro-Star International Co., Ltd. B550M PRO-VDH WIFI (MS-7C95)
BIOS American Megatrends International, LLC. 2.80
CPU Information
Name AMD Ryzen 5 5600X
Topology 1 Processor, 6 Cores, 12 Threads
Identifier AuthenticAMD Family 25 Model 33 Stepping 2
Base Frequency 4.65 GHz
L1 Instruction Cache 32.0 KB x 6
L1 Data Cache 32.0 KB x 6
L2 Cache 512 KB x 6
L3 Cache 32.0 MB
Instruction Sets sse2 sse3 pclmul fma3 sse41 aesni avx avx2 shani vaes
Memory Information
Size 15.5 GB
DIMM DDR4 Synchronous Unbuffered (Unregistered) 3600 MHz (0.3 ns)
Device Name NVIDIA GeForce RTX 3070
Driver Version: 595.58.03 CUDA Version: 13.2
Max Clocks
Graphics : 2100 MHz
SM : 2100 MHz
Memory : 7001 MHz
Video : 1950 MHz
Temperature
GPU Current Temp : 45 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 93 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Average Power Draw : 24.58 W
Instantaneous Power Draw : 24.54 W
Current Power Limit : 280.00 W
Requested Power Limit : 280.00 W
Default Power Limit : 280.00 W
Min Power Limit : 100.00 W
Max Power Limit : 350.00 W
Check if you’re not running in power‑save mode. Status and notifications in the bottom right > Power and battery. In power‑save mode even disk speeds are limited basically everything gets throttled.
I checked and it was already set to performance.
