Led matrix tool
For those who don’t know what it is, it is a part for the framework 16 https://frame.work/products/16-led-matrix?v=FRAKDE0001
I found this tool that lets me display statuses and other things on the LED matrix GitHub - MidnightJava/led-matrix: System Monitor display for Framework 16 LED Matrix input module · GitHub
They just made some patches so it can run on Bazzite (I haven’t encountered any issues yet after the fix but there could be some that I haven’t discovered yet)
I was thinking that there should be a ujust command that will set up all the tools needed for LED Matrix on the framework 16. First, the ujust command should check if it is a framework 16 and if not, it would prompt that it isn’t and would give the option to continue anyways in case of an error. Then it should install the tool and go from there.
