Layering Packages on Bazzite with `rpm-ostree`
rpm-ostree
rpm-ostree Overview
Notice: Using rpm-ostree irresponsibly can be destructive.
Attention: Layering packages may prevent updates and may cause several issues until the layered packages are uninstalled.
Install Fedora Linux packages by installing them with rpm-ostree.
  • This is known as “layering packages” to the image.
  • Layering packages will require a system reboot when it finishes creating the new deployment with the package(s) added to your image.
  • Use this method as a last resort and for anything at a “system-level” only.
Common rpm-ostree Terminal Commands:
rpm-ostree install <package>
Installs Fedora package(s) to the system that stay between updates.
rpm-ostree uninstall <package>
Uninstalls any layered packages added to the system.
rpm-ostree search <package>
Search for Fedora packages that can be installed.
RPM packages installed on the host
Fedora containers should be used for most RPM files, but sometimes they need to be installed to your host.
You can install RPM files to your host with rpm-ostree by entering:
rpm-ostree install <package>.rpm
You may need to copy the full path (/path/to/rpmfile.rpm) for it to install properly.
Note: The downside of installing local RPM files outside of the Fedora repositories is updates for the specific RPM package will not apply automatically.
How do I install COPR repositories?
Note: It is highly advised to not use third-party COPR repos if possible, so be aware there are risks associated with it including broken updates until removed.
  1. Download the .repo file and save it to /etc/yum.repos.d/
  2. Then install the package with rpm-ostree
  3. Reboot
If you experience issues updating your system due to GPG signature issues, then this can be fixed by either removing the COPR repository, or editing the file by changing gpgcheck=1 to gpgcheck=0 (or similar) and saving it at your own risk.
There is also an experimental copr utility script that ships with Bazzite. Run copr --help in the terminal for to see usage documentation, and the source code for the helper script can be found here.
MAJOR caveats using rpm-ostree
Layering packages are mostly intended for system-level applications, libraries, and other dependencies. It is recommend by upstream to use all of the methods above before installing software with rpm-ostree. Typical users should not be using rpm-ostree to install end-user graphical applications.
Layering packages can cause severe consequences including:
  • Break upgrades or prevent rebasing.
  • Conflict with existing packages as part of the image leading to dependency issues.
  • Updates will take longer to download as you layer more packages to your system.
  • Eventually package layering will be removed later in the future for Fedora Atomic Desktop and is only used currently as a crutch for the current software ecosystem on desktop Linux.
It is highly recommended to only use this command when absolutely necessary especially if the application can be obtained through other methods.
How to remove ALL Layered Packages
If you run into issues upgrading due to a layered package conflict, then either optionally uninstall the conflicted package(s) or remove all layered packages with this command:
rpm-ostree reset
Image Information
See information about image build date, update channel, layered packages, etc. by entering this command in a host terminal:
rpm-ostree status
Project Website
See also: Using rpm-ostree
← Back to Installing and Managing Software on Bazzite
