Rpm-ostree layered VPN not starting
Hello there, i am using bazzite and attempted to install the Windscribe rpm file using rpm-ostree install. I was successful in doing so, but when i attempt to launch the client, the client displays an error ‘Failed to Start’ and states that it is malfunctioning. Is there something else i can do to get the client on my bazzite? I have been enjoying using it a lot and found almost everything i need via Flatpak, but this one appears to need the rpm to work.
Did you try to install it in a distrobox/container and launching from there?
If it works, then you can export it to the host with distrobox-export
Such VPN clients often need a systemd service to be enabled. Try this
sudo -i
systemctl enable #press TAB key
and see if something like windscribe-daemon.service exists.
Dnf seems to enable these services automatically, rpm-ostree doesnt.
You might want to change the title to “rpm-ostree layered VPN not starting” as the “install local rpm” part worked fine.
Also you might want to ask them to create a repo, as not having one is an unneeded security risk. See the issue on that topic which got closed as they 1. Have no idea of immutable distros and 2. think their builtin updater is a good solution.
Maybe I was a bit mean in that comment haha, but you could add one there, to show your interest. (I think if they offer a paid service it is more okay to demand secure practice, unlike in other FOSS projects)
yes i did using a Fedora container and got the same error message so did not go down the export route.
You need to run a VPN client on your host OS.
thanks for the feedback, changed the title as suggested. I did not see the windscribe service running after checking. That issue you linked sounds like they are claiming they don’t have the support to do anything for linux beyond a deb/rpm file to download which is a bummer.
I mean they actively implement an updater process in their app, which is typical behavior on bad operating systems that dont have repositories. This is not lack of resources, they are hosting their releases somewhere and just need to add the bits of metadata to make it 2 official repos.
Did you try enabling a service for windscribe?
yes i understand this, but getting them to change might be a tall order at this point. Do you mean adding it as a OpenVPN connection via KDE networking settings?
this works, but depending on your threat model, this may have another issue:
(Unlike most VPN clients, using the KDE/GNOME GUI for VPN connections has no leaking protection)
Yea im not really ok with the compromises i would need to make to go the route of the built in KDE solution.
this will hopefully be resolved soon with a systemwide fix. But note that VPN apps make money and have paid developers, this is a big factor.
see the fedora discussion thread for more interesting infos!
Read this today, sounds like there are larger issues with this provider than i realized:
this is VERY important.
Do NOT install Windscribe.
Their serverside code may be just as bad, but at least using an official Wireguard or OpenVPN app will improve this a ton
@werner,
are you saying windscribe can be use through Wireguard or OpenVPN?
If yes how do you do it?
@coastal133,
what did you end up doing? are you using windscribe?
What’s your advice for a better vpn?
Thanks guys
I am not happy to say this as I am a big fan of the project and all the amazing things it has been able to accomplish for the Linux community. To be honest, this was one of the reasons I am not able to daily drive Bazzite as i could not find a suitable solution to this issue.
In reference to other VPNs, I did just read a forum post (linked below) that apparently there are safety concerns about providers who use Electron based apps (I am not sure if these even work with Bazzite, but just throwing it out there as a few alternatives that are mentioned by name offer desktop based apps that have safety concerns)
Well this is an issue on about every distro, if you run these apps.
windscribe is a bad VPN company. VPNs are made for you to connect to a different network securely. It is not a privacy technology.
So if they dont even manage to have a secure app, why would you trust them with all your traffic?
And yes, VPN apps all use OpenVPN, Wireguard or other obscure VPN technologies. If they dont provide a config to use it with a regular client, ask them
MullvadVPN is better. Their app uses electron but it can be used without it, using the cli utility and a custom autostart script
The solution might be a future when VPN providers provide flatpak as a standard option for Linux users (do any of them do this now?)
This link provides some helpful workflows for people who use Mullvad and i appreciate you sharing it!
this is not possible, because desktop Linux (unlike Android) does not have the needed VPN features integrated in the system
killswitch, always on are not a thing, so to prevent leaks, Mullvad needs to do all of that themselves, with a systemd service to block early boot connections and more
thanks for the link @werner pretty cool tips!
