This is pre-installed on KDE images.
Instructions
- Open KDE Partition Manager
- Locate the disk and partition you want to mount
- Right click on the partition and click “Edit Mount Point”
- Select “Identify by: UUID” (This will guarantee you mount THIS partition instead of a different one if the device nodes change for some reason)
- Select a mounting path (You would want to use
/var/mnt/gamesor something similar for permanent mounts) - Untick all the boxes in the graphical application if they are checked
- Click “More…” and add extra options depending on what filesystem is on the partition (read the “Filesystem Arguments” section)
- Click OK on both windows to save the mount points.
- A message will appear that the actions will edit
/etc/fstab(Click “OK” to continue) - Mount the disk manually in KDE Partition Manager and enter your sudo password
- Open the terminal to test the mounts by running the command:
sudo systemctl daemon-reload && sudo mount -a
- If no errors appeared then it should be safe to reboot.
Note: If errors occur, then research the error and undo what you did and try again. Redo the previous two steps in the terminal (see CLI method down below and research how to use fstab) as KDE Partition Manager might not give a good error to search for if the test mount fails.
Display Name should be added too. Name it whatever you want it to be identified as.
Required additional options depending on filesystem
Use the below generic options depending on your filesystem (these are just good defaults)
You can copy+paste these into the “More..” dialog and they will be valid
Note: “Users can mount and unmount” is an optional setting.
Filesystem arguments
Warning: If a drive is formatted, then do not remove it from
/etc/fstab, so the “nofail” option is a must to avoid issues with booting.
Example: btrfs requires these additional options.
BTRFS:
defaults,compress-force=zstd:3,noatime,lazytime,commit=120,space_cache=v2,nofail
Ext4:
defaults,noatime,errors=remount-ro,nofail,rw,users,exec
NTFS:
defaults,noatime,nofail,rw,users,exec
Note: Do not use the NTFS filesystem for game library storage in Bazzite, and it is not supported and you will get lots of issues with it. NTFS is not intended as a game drive for Bazzite.
Advanced Options (Not required for most setups)
Change at your own risk!
Information about compression:
3 is a good balance, older CPUs should use 1.
Information about subvolumes:
use subvol=name as an option, KDE and GNOME Disks let you only mount 1 subvolume through the GUI, you can mount the root with subvol=/ if a default subvolume is configured in the filesystem.
Installing KDE Partition Manager on non-KDE images
If you would like to install this, then it can be layered to your system by entering in a terminal:
rpm-ostree install kde-partitionmanager
Reboot your system after it has finished installing the terminal.
