hi! linux noob here, and new to bazzite as well….
an app I use a lot (ente auth) isnt opening so I tried opening it in terminal to see what was happening…
me@mycomputer:~$ flatpak run io.ente.auth
enteauth: /usr/lib/x86_64-linux-gnu/libcurl.so.4: no version information available (required by /app/share/enteauth/lib/libsentry.so)
(io.ente.auth:2): Gtk-WARNING **: 18:35:16.107: Theme parsing error: gtk.css:1:82: Failed to import: Error opening file /home/me/.local/share/gnome-shell/extensions/kiwi@kemma/icons/gtk3.css: No such file or directory
flutter: [ente_logging] [INFO] [2025-09-14 18:35:16.252640] log file for today: File: ‘/home/me/.var/app/io.ente.auth/data/enteauth/logs/2025-9-14.txt’ with prefix
flutter: [ente_logging] [INFO] [2025-09-14 18:35:16.252640] app version: ‘4.4.0+440’
flutter: [main] [INFO] [2025-09-14 18:35:16.252715] Starting app in foreground
flutter: [Configuration] [INFO] [2025-09-14 18:35:16.252907] Skipping temp folder clear
I turned off the gnome extension thats mentioned & tried it again…
flutter: [ente_logging] [INFO] [2025-09-14 18:36:05.483190] log file for today: File: ‘/home/me/.var/app/io.ente.auth/data/enteauth/logs/2025-9-14.txt’ with prefix
flutter: [ente_logging] [INFO] [2025-09-14 18:36:05.483190] app version: ‘4.4.0+440’
flutter: [main] [INFO] [2025-09-14 18:36:05.483271] Starting app in foreground
flutter: [Configuration] [INFO] [2025-09-14 18:36:05.483466] Skipping temp folder clear
I’ve also uninstalled and reinstalled the flatpak to no avail either. Does anyone have insight into what I should do?
