Happy to raise an issue for this if I can confirm: has anyone else had Gnome’s remote desktop break in Fedora 42 with a core dump? I get:
# systemctl status gnome-remote-desktop.service
× gnome-remote-desktop.service - GNOME Remote Desktop
Loaded: loaded (/usr/lib/systemd/system/gnome-remote-desktop.service; enabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/service.d
└─10-timeout-abort.conf
Active: failed (Result: core-dump) since Fri 2025-06-13 21:27:39 BST; 9min ago
Invocation: 9d6ecac1edc24dfeaa20d641ff5545bc
Process: 982595 ExecStart=/usr/libexec/gnome-remote-desktop-daemon --system (code=dumped, signal=ABRT)
Main PID: 982595 (code=dumped, signal=ABRT)
Jun 13 21:27:39 host systemd[1]: gnome-remote-desktop.service: Main process exited, code=dumped, status=6/ABRT
Jun 13 21:27:39 host systemd[1]: gnome-remote-desktop.service: Failed with result 'core-dump'.
Jun 13 21:27:39 host systemd[1]: Failed to start gnome-remote-desktop.service - GNOME Remote Desktop.
Looking at the log:
Jun 13 21:28:28 host audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-coredump@27-982898-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 13 21:28:29 host systemd-coredump[982899]: [🡕] Process 982895 (gnome-remote-de) of user 974 dumped core.
Module /usr/libexec/gnome-remote-desktop-configuration-daemon from rpm gnome-remote-desktop-48.1-1.fc42.x86_64
I have found this thread on Fedora forums which claims it is because the configuration directory should be updated to have user gnome-remote-desktop as owner:
I had to run the following command, and then the daemon could start successfully:
chown -R gnome-remote-desktop: /var/lib/gnome-remote-desktop
Well, indeed on my Bluefin:
root@host ~# ls -al /etc/systemd/system/graphical.target.wants/gnome-remote-desktop.service
lrwxrwxrwx. 1 root root 52 Jun 8 20:49 /etc/systemd/system/graphical.target.wants/gnome-remote-desktop.service -> /usr/lib/systemd/system/gnome-remote-desktop.service
root@host ~# grep User /etc/systemd/system/graphical.target.wants/gnome-remote-desktop.service
User=gnome-remote-desktop
root@host ~# ls -ald /var/lib/gnome-remote-desktop
drwx------. 1 saslauth gnome-remote-desktop 24 May 6 2024 /var/lib/gnome-remote-desktop/
So it seems the service is configured to run as user gnome-remote-service but this user does not seem to exist in /etc/passwd so I cannot use the suggested fix from the Fedora forums.
Anyone else getting this? How would you go about working around this? Is it possible Bluefin needs to add a new user to /etc/passwd to accommodate the application?
