Hi all!
I have an issue, it has more to do with gnome than with bluefin, so I apologize if the address is wrong. After leaving the PC in sleep and returning to it I find I was logged out of gnome into the GDM. Now the problem has excalated a bit in the sense that when I click on the folder in app-drawer view on gnome, the same thing happens. If extensions are deactivated, the problem is solved, so that seems to be the cause. Either dash-to-dock or blur-my-shell seems to be the cause.
This is the error log, usually always the same after the logout bug:
I experienced the same when I was on Fedora 40, so this is probably not bluefin related. Just wanted to share. If somebody has a fix, I would be very happy to get back those dinosaurs on a shell too… ![]()
