Hello! I am new to Bazzite. Trying to switch from Fedora 39.
Installed Davinci Resolve on Bazzite. It works fine. Now i need to install Dehancer (dehancer.com) plugin for it. It is executable file. I get the following error when running it.
Google knows nothing about installing third-party Davinci plugins on Bazzite.
Help me, please
I’m not currently using Bazzite, but IIRC the Davinci Resolve installer script installs it to a distrobox container? So what you need to do is find the shortcut to your Davinci Resolve, then see what distrobox container it is, then do distrobox enter <container-name> first before running the script.
Otherwise, the only other way is to create an OFX or a Plugins folder and use a .service file to mount it to /usr/OFX or /usr/OFX/Plugins respectively. I can’t really try it out right now, though, maybe someone else can help?
Hi! I’ve installed the plugin in distrobox and then copied it from distrobox to folder in home folder, applied root roor / 755 to .bundle file. Added custom folder of OFX plugin to .desktop run app. Now it showning in DaVinci but failed to load, one of dependencies not installed in bazzite. And I don’t know how to fix it. Sad
I’ll try Distrobox way for Resolve
