Huiontablet Driver Installation - Read-only file system
Hello, new Bazzite user here;
Running into an issue attempting to install the proprietary Huion drivers for my new Kamvas Pro 16. When i run install.sh, it produces the following error:
/run/media/system/2TB_Drive/HuionTablet_LinuxDriver_v15.0.0.175.x86_64/.
Uninstall the old driver first.
正在卸载旧版本驱动…
close core
close tablet
ls: cannot access ‘/var/lib/dpkg/info’: No such file or directory
Uninstallation Succeeded !
驱动卸载成功 !
cp: cannot create regular file ‘/usr/lib/udev/rules.d/20-huion.rules’: Read-only file system
/usr/lib
./huion/huiontablet
cp: cannot create directory ‘/usr/lib/huiontablet’: Read-only file system
can not find start script
Asked a friend of mine and they said that my main drive being read-only is not something that should happen. This isn’t the case, as I had just ran ujust update and successfully updated my OS. Any help would be appreciated.
