How to upgrade Aurora?
Running ujust --choose ➡️ update doesn’t seem to upgrade Aurora to version 41 from 40.
So, how do I upgrade to 41? Same as Kinoite? That is:
rpm-ostree upgrade
shutdown -r now
ostree remote refs fedora | grep kinoite | grep $(uname -m)
fedora:fedora/41/x86_64/kinoite
What image are you on (rpm-ostree status)? And what does ujust update command give you?
Forget everything, apparently I’m on 41 since yesterday :smiley:
Well it seems you are already on the newest image
EDIT: Was too slow :smiley:
To answer my own question for future peeps searching for answer:
ujust update is all you need.
