How to toggle ipv6?
I just noticed that for some (obscure) reason, one of my Bazzite KDE machines has ipv6 disabled.
How can I verify/configure my ipv6 settings on UB distros?
Been along time since I used KDE but I would assume network settings would be the place to start. Check which way you connect ,Ethernet or Wi-Fi and the option should be there to enable/Disable. Using Wi-Fi you should check ipv6 settings on your Wi-Fi connection too, hope that helps
ipv6 is set to “automatic” in Network Manager for both Ethernet and WI-FI, toggling it on and off has no effect.
The PC has all the default values as per installation, I have never changed anything and all the other machines in my network have working IPv6.
Thanks anyway.
