Wi-Fi Issues (Legion Go). Can't connect to any 6GHz networks
I’m dual booting Windows 11 & Bazzite on a Legion Go. In Windows 11, I can connect to 6GHz networks. In Bazzite, I can’t. I’m hoping there’s a Linux expert out there that can help (please and thanks!)
I may just have to accept that my Legion Go will never be able to connect to 6GHz networks in Bazzite, but the Wi-Fi card is clearly compatible with 6GHz networks as it can connect in Windows 11 just fine, so it feels like there must be a fix for this somewhere. It’s not a huge issue if it can’t be solved, just annoying.
I’ve followed a few guides online that suggested the following:
● Turning off Windows 11 fast boot.
● Turning off Windows 11 hibernate.
● Turning off Wi-Fi power saving.
● Changing the Wi-Fi regulatory domain to my country (New Zealand) with sudo iw reg set NZ (this does nothing; when I use iw reg get the output is the same as before using sudo iw reg set NZ).
● Using sudo nano /etc/modprobe.d/cfg80211-regdomain.conf to create a file with the line options cfg80211 ieee80211_regdom=NZ (also seems to do nothing).
● Using sudo nano /etc/default/crda to create a file with the line REGDOMAIN=NZ (also seems to do nothing).
● Using echo “options mt7921_common disable_clc=1” | sudo tee /etc/modprobe.d/mt7921.conf to disable Coexistence Legacy Calibration.
It seems that nothing I’ve tried can get it to work (I’m very new to Linux, so it’s totally possible I’ve been blindly following gibberish guides for other distros that just won’t work on Bazzite…). Note that Bazzite can see my 6GHz network (though sometimes it takes a few minutes for the network to show in my list of available networks), but it just fails to connect every time I try (WPA3 security is enabled). I can only connect to the 2.4Ghz and 5Ghz networks.
I have an MSI laptop that is also compatible with 6GHz networks, and I thought I’d give that a go to test if it’s an issue with my Wi-Fi router and Linux, or if it’s an issue with my Legion Go specifically.
To test the issue, I booted Live Environment ISOs of the following Linux distros on both my laptop & my Legion Go:
● Fedora 42
● Debian 12
● CachyOS 250422
● Linux Mint 22.1
In every instance, my laptop can connect to my 6Hz network in Linux but my Legion Go cannot. Maybe the Wi-Fi card in the Legion Go is just not fully compatible with Linux?
To compare, here’s some of the terminal output from the Fedora 42 Live Environment from the Legion Go compared to my laptop - Unsure if this is of any value?
Legion Go
liveuser@localhost-live:~$ iw reg get
global
country US: DFS-FCC
(902 - 904 @ 2), (N/A, 30), (N/A)
(904 - 920 @ 16), (N/A, 30), (N/A)
(920 - 928 @ 8), (N/A, 30), (N/A)
(2400 - 2472 @ 40), (N/A, 30), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), AUTO-BW
(5250 - 5350 @ 80), (N/A, 24), (0 ms), DFS, AUTO-BW
(5470 - 5730 @ 160), (N/A, 24), (0 ms), DFS
(5730 - 5850 @ 80), (N/A, 30), (N/A), AUTO-BW
(5850 - 5895 @ 40), (N/A, 27), (N/A), NO-OUTDOOR, AUTO-BW, PASSIVE-SCAN
(5925 - 7125 @ 320), (N/A, 12), (N/A), NO-OUTDOOR, PASSIVE-SCAN
(57240 - 71000 @ 2160), (N/A, 40), (N/A)
liveuser@localhost-live:~$ lspci -knn | grep -iA3 net
pcilib: Error reading /sys/bus/pci/devices/0000:00:08.3/label: Operation not permitted
01:00.0 Network controller [0280]: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter [14c3:0616]
Subsystem: Lenovo Device [17aa:e0c7]
Kernel driver in use: mt7921e
Kernel modules: mt7921e
liveuser@localhost-live:~$ iw dev
phy#0
Unnamed/non-netdev interface
wdev 0x2
addr XXXXXXXXXXX
type P2P-device
txpower 3.00 dBm
Interface wlp1s0
ifindex 2
wdev 0x1
addr XXXXXXXXXXX
ssid TP-Link_6366_5G
type managed
channel 36 (5180 MHz), width: 160 MHz, center1: 5250 MHz
txpower 3.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
Laptop
global
country 00: DFS-UNSET
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country US: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-320MHZ
(5190 - 5210 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-320MHZ
(5210 - 5230 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-320MHZ
(5230 - 5250 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-320MHZ
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ
(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
(5945 - 7065 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-320MHZ, PASSIVE-SCAN
(7065 - 7105 @ 40), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(7105 - 7125 @ 20), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:7af0] (rev 11)
DeviceName: Onboard - Ethernet
Subsystem: Rivet Networks Device [1a56:1672]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake-S PCH Serial IO I2C Controller #0 [8086:7acc] (rev 11)
06:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Killer E3000 2.5GbE Controller [10ec:3000] (rev 06)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:139a]
Kernel driver in use: r8169
Kernel modules: r8169
phy#0
wdev 0x2
addr XXXXXXXXXXX
type P2P-device
Interface wlo1
ifindex 3
wdev 0x1
addr XXXXXXXXXXX
ssid TP-Link_6366_6G
type managed
channel 69 (6295 MHz), width: 160 MHz, center1: 6345 MHz
txpower 22.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
Did you ever resolve this? I’m seeing the exact same behavior on my Legion Go S Steam OS edition.
It fixed itself with a bazzite system update eventually. I suspect a driver issue or something was fixed in a later linux kernel update, but i haven’t verified this.
If you’re on Steam OS instead of bazzite, you might be on a different version of linux so your driver or kernel version might not have whatever fix bazzite received.
Any chance you can share what the current uname -a output is to show current kernel version?
Ive had a Legion Go for well over a year, been running Bazzite on the entire time, I never actually booted Windows at all, well I booted it right off the drive on day 1, Its never had an issue connecting my Unifi AP6’s, pretty sure they are all 6Ghz, I use mine pretty much every night as well, might be something different with my access points?
I was having the Wifi drop intermittently due to it hunting for alternative base stations, but locking to a BSID fixed that.
