I installed bluefin-dx-nvidia yesterday (Fedora 41) and am having trouble properly disabling the ibus service. I would like to use PaperWM, but the Super + . key combination consistently opens an interactive text input in IDEs or the terminal.
I can’t seem to find a way online to disable this without editing something in the filesystem. Any help would be appreciated!
Just discovered toolbox. My bad. Using it solved my problem.
Edit: for posterity, in case another person comes across this, I just ran toolbox enter and installed Toolbx, then I was able to run ibus-setup normally. All good!
Oh, yeah. I had been doing this before I discovered the toolbox solution but particularly with the PaperWM shortcut I didn’t want to have to run ibus exit every time I log in.
