Hello there, I have an issue ever since Bazzite with the Fedora 41 base where the startup animation of gaming mode gets cut off.
Every few updates it gets worse for me and as of now only the last half second can be heard and nothing can be seen anymore of it.
Adding things to startup like sunshine make that problem even worse.
My specific setup is a Gigabyte A620i AX board with a Ryzen 7500F CPU and RX 6800 reference card, also AMD. I’m using the Bazzite-deck-gnome image for a month now with a clean install, been using the KDE version before that.
