Bazzite crashes when shutting down from Gaming Mode
Since a few days ago, Bazzite has stopped shutting down properly when I shut down from Gaming Mode. It was working fine last week.
When I press Shut down, the Steam session closes and I reach the screen with the bazzite logo and the spinner graphic on a black screen. But even after waiting for 1 hour, the computer never powers off. The screen will just crash.
I’m using the Home Theatre PC version of Bazzite, with KDE desktop.
If I shut down from the KDE desktop, the computer powers off fine. This only occurs when I select “Shut down” from within Gaming Mode.
What can I do to troubleshoot or resolve this? Could this be due to a recent Bazzite update? I’m running the kernel version 6.15.4-106.bazzite.fc42.x86_64 (64-bit)
Here is the output of sudo journalctl -b -1 -e
Jul 18 21:19:32 bazzite kernel: audit: type=1305 audit(1752869972.908:1010): op=set audit_pid=0 old=1136 auid=4294967295 ses=4294967295 subj=system_u:system_r:auditd_t:s0 res=1
Jul 18 21:19:32 bazzite systemd[1]: auditd.service: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Stopped auditd.service - Security Audit Logging Service.
Jul 18 21:19:32 bazzite audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=auditd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termina>
Jul 18 21:19:32 bazzite kernel: audit: type=1131 audit(1752869972.911:1011): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=auditd comm="systemd" exe="/usr/lib/systemd/syst>
Jul 18 21:19:32 bazzite audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=>
Jul 18 21:19:32 bazzite systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Stopped systemd-tmpfiles-setup.service - Create System Files and Directories.
Jul 18 21:19:32 bazzite systemd[1]: Stopped target local-fs.target - Local File Systems.
Jul 18 21:19:32 bazzite kernel: audit: type=1131 audit(1752869972.912:1012): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/>
Jul 18 21:19:32 bazzite systemd[1]: Unmounting boot-efi.mount - /boot/efi...
Jul 18 21:19:32 bazzite systemd[1]: Unmounting sysroot-ostree-deploy-default-var.mount - /sysroot/ostree/deploy/default/var...
Jul 18 21:19:32 bazzite systemd[1]: Unmounting tmp.mount - Temporary Directory /tmp...
Jul 18 21:19:32 bazzite systemd[1]: Unmounting var-home.mount - /var/home...
Jul 18 21:19:32 bazzite systemd[1]: Stopping systemd-journal-flush.service - Flush Journal to Persistent Storage...
Jul 18 21:19:32 bazzite systemd[1]: boot-efi.mount: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Unmounted boot-efi.mount - /boot/efi.
Jul 18 21:19:32 bazzite systemd[1]: sysroot-ostree-deploy-default-var.mount: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Unmounted sysroot-ostree-deploy-default-var.mount - /sysroot/ostree/deploy/default/var.
Jul 18 21:19:32 bazzite systemd[1]: tmp.mount: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Unmounted tmp.mount - Temporary Directory /tmp.
Jul 18 21:19:32 bazzite systemd[1]: var-home.mount: Deactivated successfully.
Jul 18 21:19:32 bazzite systemd[1]: Unmounted var-home.mount - /var/home.
The computer still had power at 23:00, 1 hour and 40 minutes after the last entry in that log.
