any one can help me
im stuck in here
my device
asrock b550m itx
ryzen 5600g
give it 30 more minutes and let me know what happens
thanks for the answer. but i waited almost 2 hours no change at all.
What is your internet speed like? This is Steam updating in the background.
internet speed at my house is only 20mbps.
After the installation process, I restarted the PC and an update like this appeared. Am I wrong in choosing the ISO image?
No, this is the handheld/htpc image with gaming mode. As long as you have a modern AMD GPU or Intel Arc GPU, it should be okay. Report the issue here or on our Discord under #bazzite-help
Edit: we do have desktop images without steam gaming mode, but if you really want that, then this will have to be solved.
