Help install cloudflare-warp
I just follow the cloudflare install instructions:
Install the repository with yum (replace with the release version number):
The supported versions are:
8
Add cloudflare-warp.repo to /etc/yum.repos.d/
curl -fsSl https://pkg.cloudflareclient.com/cloudflare-warp-ascii.repo | sudo tee /etc/yum.repos.d/cloudflare-warp.repo
Update repo
sudo yum update
Install
sudo yum install cloudflare-warp
But the installing failed and now I call install again this error appear:
error: Package/capability ‘cloudflare-warp’ is already requested
Did you do a restart?
Did you do this in a Fedora distrobox? If you are installing on the host you would need to use rpm-ostree install instead of sudo yum install
