Help: Dock disappeared and the top bar is not translucent anymore
Hi, when I booted my computer today, I got into GNOME, but then the screen went nuts (black/white dots) for a brief second and now my system looks like this:
Dunno if NVidia drivers crashed or something, but I tried rebooting three or so times already, but it does not just “fixed itself”. Any guidance on how to provide you with more detailed info is hugely appreciated.
Thanks, and sorry if this is just some misclick or something.
I also miss some buttons (like gsconnect) in QS:
Did tou check that the extensions are not just disabled? You can check the Extension Manager app
Yep… that was it. So most likely GNOME just crashed and started itself in “safemode” without extensions, right?
Yeah it usually does that if ot actually hard crashes
