Hello, I am currently using Bazzite 40, when I try to open a specific video with Clapper I get this error. Since the distro is atomic I am not even trying to install the plugin myself. Any ideas on this?
It will help if you give more information. Like what OS are you running? The below command should give us that information.
rpm-ostree status
Then information on how you are running the application would be helpful. For example, I assume you are running the app through flatpak, but confirmation would be nice. If you do not know, just telling us how the app was installed would be helpful.
I personally can play av1 videos on the flatpak version of Clapper. If you are doing the same, then maybe trying a different video player like VLC might help. Even if you wish to use Clapper, testing other video players can help narrow down the issue.
rpm-ostree status
State: idle
Deployments:
ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia-open:latest
Digest: sha256:821cc798ce42c401cd9ef392689128e4ee039ba7d58001386d71268830a7d4d5
Version: 41.20241112.1 (2024-11-12T23:59:36Z)
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia-open:latest
Digest: sha256:ee182e63fef540a138c652c369158e85e5f30037eb5be5296f4e51a9a29fcc24
Version: 41.20241112 (2024-11-12T08:30:51Z)
Digest: sha256:a9a6906e6ab46d2d86b4c0ef963ea8ce5728a63e4e94905d837a19c305d76dc3
Version: 41.20241104 (2024-11-04T05:01:05Z)
I tried VLC but it will not open the file correctly either, does not specify the reason. And actually, the file extension is mp4. It does open on Windows using Pot Player, so it is not a file problem.
rpm-ostree status
State: idle
Deployments:
ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome-nvidia:stable
Digest: sha256:d56cf1d176859a1df52c53867cd155b75455987dae275d1aa4df56e506fcde87
Version: 41.20241104 (2024-11-04T04:59:54Z)
Diff: 2200 upgraded, 9 downgraded, 119 removed, 76 added
LayeredPackages: snapd● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome-nvidia:stable
Digest: sha256:28e9785f1f90699d38063655319286a01669aacdbb7ed75a90a84f78c4944799
Version: 40.20241020 (2024-10-21T05:06:50Z)
It seems like you have a lot of pending updates.
Try updating and then rebooting your system. It might help, given that a major os version has changed since you last updated.
Im pretty sure this is due to Clapper having an outdated Flatpak Runtime. You should try installing Showtime and checking if it works at all on that one instead
What kind of sorcery is this? that media player is so small in size and still is opening a video that VLC could not. Thanks.
Still, I would like to see a fix for Flatpak Clapper in the future.
You should file an issue on the Clappers github. I think there is one for the old runtime it is using but the dev has not updated it
