j0rge
November 7, 2024, 1:51pm
1
We’ve had some sporadic reports of hardware video decoding not working on certain systems. bsherman is investigating and needs data. If you want to participate here’s the issue, thanks! Title says AMD but we’re checking everything while we’re in there:
opened 04:48PM - 29 Oct 24 UTC
bug
help wanted
### Describe the bug
Bazzite does no longer hardware encoding.
### What did yo… u expect to happen?
Hardware encoding to be working out of the box
### Output of `rpm-ostree status`
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome:stable
Digest: sha256:5ca34736bf048597c1595bd52bc763491b183cf5b7624866b6959604419ce53a
Version: 41.20241029 (2024-10-29T03:42:03Z)
LayeredPackages: code containerd.io docker-buildx-plugin docker-ce docker-ce-cli docker-compose-plugin gnome-boxes
gnome-monitor-config gnome-system-monitor goverlay grsync idevicerestore mullvad-vpn
nextcloud-client-nautilus Sunshine
Digest: sha256:cdc448e1818b0f44e0fd0882fe0bf590b408259395da457cf15bebd209224b2c
Version: 40.20241020 (2024-10-21T05:01:41Z)
Pinned: yes
### Hardware
# System Details Report
## Report details
- **Date generated:** 2024-10-29 17:45:43
## Hardware Information:
- **Hardware Model:** ASUS PRIME B550-PLUS
- **Memory:** 32.0 GiB
- **Processor:** AMD Ryzen™ 5 5600X × 12
- **Graphics:** AMD Radeon™ RX 6650 XT
- **Disk Capacity:** 3.1 TB
## Software Information:
- **Firmware Version:** 3205
- **OS Name:** Bazzite 41 (FROM Fedora Silverblue)
- **OS Build:** Stable (F41.20241029)
- **OS Type:** 64-bit
- **GNOME Version:** 47
- **Windowing System:** Wayland
- **Kernel Version:** Linux 6.11.5-307.bazzite.fc41.x86_64
### Extra information or context
pimv ➜ ~ $ vainfo
Trying display: wayland
libva info: VA-API version 1.22.0
libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_22
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.22 (libva 2.22.0)
vainfo: Driver version: Mesa Gallium driver 24.2.4 for AMD Radeon RX 6650 XT (radeonsi, navi23, LLVM 19.1.0, DRM 3.59, 6.11.5-307.bazzite.fc41.x86_64)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
pimv ➜ ~ $
Specifically looking for tests on Bazzite with Intel and Nvidia GPUs.
We’ve already got reports from AMD GPUs.
Thanks!
Thank you for spelling that out and thank you all for looking into this.
I hope more people see this post and share a report, it’s really quick!
OK, I think we’ve got enough data now. Thanks all who contributed!
