I’m not sure if it’s because the new device hasn’t been supported yet. I used HHD to emulate the controller as a DS, and Steam does recognize the device as having a gyroscope, but it doesn’t actually work. During the gyroscope test, no matter how I shake the device, all values remain at 0 and stay completely static.
Has anyone experienced this issue or found a workaround? Any help would be appreciated!
New discovery: If I perform an update (or downgrade) on the HHD overlay interface and then restart, the gyro works normally. However, once the system goes to sleep, the gyro stops functioning again. It has to be a system update to work; a simple restart has no effect.
What kind of gyro does the GPT Win Mini 2025 use?
My GPT Win Mini 2024 has a bmi160. And I have the same problem.
QuickFix for my 2024 … Reddit - Dive into anything
