GNOME-Shell Optimisation in Bazzite
Just a quick question:
Is the gnome-shell-optimization possible to install without breaking system rules?
I was not able to find it. Only found GDM customization in Bazaar.
My goal is:
  • Change mouse cursor
- Change dekstop icons
Oh, btw: Chaning mouse size via gnome settings does not work for me on freshly installed bazzite latest version.
OKay, since no ones answers to this question, I assume bazzite is not ment to have such customisations.
Its been just over 1 day, you can’t really expect to have real time answers. This is mainly a user forum, not dev forum.
Also your question is pretty wide open one, what optimisations are you looking for?
Ehm,
Pretty wide open?
What do you understand by my goals:
My goal is:
  • Change dekstop icons
Anyways:
Let me light up your way: I am talking about a package called “gnome-tweaks“, which is available on most all major distributions but not in bazzite.
Just wanted to know whether or not the package ist available/allowed in bazzite as a immutable linux.
Hey,
It seems you are not keen to do any research (or just use the search) and expect all to be provided fast, fast, fast.
I will indulge a bit - Bazzite uses Refine, which essentially does the same thing as Gnome Tweaks.
if you want custom cursors, you download your favorite ones, navigate to .local/share/ folder and create folder named icons (if it does not exists).
Copy the folder(s) with your desired cursor there and use Refine to change the cursor.
Profit.
Great, thanks! I did not refine to be the tool in my reserches. Anyways, I know the procedure on how to get the cursors and icons changed. Just needed the tool.
Okay, I will spread this knowledge, if needed and will do a YT short about it.
