Hi all,
Refine as the tool to use for tweaking things in bazzite cannot change the following:
Position of window buttons ( maximize, minimize, close )
Switch super on keyboard layout ( as far as I know as of now. I tested a lot )
Change GTK3/4 theme
Is there another tool, that I missed?
Cheers,
AndyBee
Tuner works for me just fine
Dear Jackson
Yes, that tool can solve it. Basically it is the english clone of refine despite tuner lacks one setting.
However, you pushed me to the solution. I just had refine and tuner windows open next to each other and compared them, which is how I found out.
I was too stupid to see the possibilities in refine.
Thanks for hinting!
Yes..yes..yes… I will shortly upload the YT shorts or maybe the shorts on tiktok or wherever needed.
We need a video channel to spread knowledge about bazzite… Guess I just need to start it… okay..
