So the main issue is that the left and right trigger inputs are swapped, and I can’t use it while plugged in to charge it’s a gxt 542 muta if it helps.
Are you on Bazzite desktop? If so, I think you can use input-remapper to manually remap it, or alternatively create a Steam Input template that flips it, as quick fixes.
