Hi everyone!
After watching Jorge’s YT videos I decided to jump from Endeavour OS to Aurora DX on my backup machine. My main machine is a MacBook Pro but I also like to use my backup machine (HP EliteBook 830 G5) for Linux tests and travelling.
So far the out-of-the-box experience is nice! I had to fix the permissions for virt-manager but besides that, everything working great!
Even my headphone EQ works with “Easy Effects” as flatpak. I had that running as a normal package and was not aware that it works as a flatpak as well!
My wishlist now would be to:
Enable Intel iGPU passthrough to VMs (out-of-the-box or maybe someone can help to get this going)
Add krdp to the settings menu. I was able to overlay it to the image and it runs from the commandline, but as far as I understand it should also show up in the setting menu.
Thanks again and maybe someone could help!
Since I can only add 2 links for now, here are the iGPU passthrough references:
https://wiki.archlinux.org/title/Intel_GVT-g
Just wanted to chime in again with an update!
I switched from Aurora to Bluefin. This resolved the RDP issue but I had to work around two issues:
You have to Switch SELinux to permissive mode on the server and try connecting the client:
sudo setenforce 0
On the Mac Client you have to change use redirection server name:i:1 in the RDP file.
Links:
I was initially able to briefly enable remote desktop using this solution, but either it doesn’t stick between reboots (or maybe system updates), or something due to getting locked out of sudo for a few days is preventing that solution from...
Host: Fedora 40 WS Edition, Linux 6.9.5-200.fc40.x86_64, gnome-remote-desktop46.2-1.fc40 Client: MacOS Sonoma, Microsoft Remote Desktop 10.9.8 (2217) Remote login fails with authentication error that doesn't make...
Regarding iGPU passthrough I was successful as well!
Below is my initial config followed by two guides that should get you going!
Virt-Manager
# Setup groups
ujust dx-group
# Fix permissions
sudo restorecon -rv /var/lib/libvirt/
sudo restorecon -rv /var/log/libvirt/
# Enable kvmfr for looking-glass
ujust configure-vfio kvmfr
Intel GVT-g iGPU passthrough
# Check kernel args
sudo rpm-ostree kargs
sudo rpm-ostree kargs \
--append-if-missing="i915.enable_gvt=1" \
--append-if-missing="i915.enable_fbc=0" \
--reboot
Loading the GVT-g modules at boot
Use your favorite text editor to create a file called /etc/modules-load.d/kvm-gvt-g.conf and place the following content in it:
kvmgt
vfio-iommu-type1
vfio-mdev
Creating the virtual GPU
Follow this guide for creating and persisting the GPU:
Edit XML of your VM to add the shared memory
sudo EDITOR=nano virsh edit Win11
# change domain
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
# add commandline options for shared memory
<qemu:commandline>
<qemu:arg value='-device'/>
<qemu:arg value='{"driver":"ivshmem-plain","id":"shmem0","memdev":"looking-glass"}'/>
<qemu:arg value='-object'/>
<qemu:arg value='{"qom-type":"memory-backend-file","id":"looking-glass","mem-path":"/dev/kvmfr0","size":33554432,"share":true}'/>
</qemu:commandline>
Build looking-glass-client
https://universal-blue.discourse.group/docs?topic=956
Here’s a must-see video how this is done on Ubuntu 20.04:
I think that was all. Let me know if I missed anything or if you have questions!
