[Feature Request] Make the System Updater graphical and add notifications
As title says.
As far as i know, Bluefin doesn’t say when is updating, how much until the update is complete, and if the update is a success or not.
I believe it should keep using the ujust command behind the scenes but have a GUI that shows its output. Having a tray icon for when updates are going on should also help instead of checking by the system monitor why there is activity.
Maybe this script could be implemented. Best way for monitoring and alerting of running Bluefin version - #4 by indibart
