Hi again, I decided to have another go at Bazzite and try and install some fan control software.
I came across a command to install CoolerControl…
ujust install-coolercontrol
after install and reboot
ran the commands to check for deamon…
sudo systemctl enable --now coolercontrold
sudo systemctl status coolercontrold
rebooted and hey presto I have a solid piece of software capable of controlling all my fans.
How to use CoolerControl…
Hope that helps!
If anyone knows of a reason why this may be a bad move please let me know. Its my only concern about this now. Thanks :O) I am quite new to Linux.
