clicking
new window reopen the same error window.Closing and restarting vscode open the same error…
Might be a link with this problem I have for a while now with devpod
thanks for your help
new window reopen the same error window.Might be a link with this problem I have for a while now with devpod
Still the same unfortunately…
I had the same symptom on my machine some time ago. VSCode failed to launch because of missing fonts · Issue #876 · ublue-os/bluefin · GitHub . Maybe you have played around with the default fonts? You could try the solution that I used in that issue.
aha! thanks a lot @nikostourvas ! that did the trick! I appreciate your help
