I have installed the bluefin dx version. Shouldn’t dev containers with VS code work out of the box? I get the following message:
Thanks
Not at my machine to check the exact command currently.
If you haven’t already there should be a ujust dx-groups command you can run from terminal. It will add your user profile to all the needed groups including docker.
It will say you need to logout and back in to see the effect but I personally needed to fully reboot for it to be recognized.
Thanks. That worked!
