DevPod - Closes as soon as screen is drawn
New install of Bluefin with nvidia. After a fresh install when launching DevPod it will draw the screen and then close out immediately. At first I believed it was a bad install, but I’m not seeing any errors and I can run the downloaded AppImage of DevPod without issues.
To add I also threw bluefin on my laptop with an intel agpu and DevPod launched w/o issue after the initial install.
Not sure if DevPod is baked into the Developer experience or if it’s an AppImage as well and it’s possible the version and the combo of a three screen setup with an NVIDIA GPU.
Nvidia + DevPod has been an issue for awhile. It should of been resolved with the latest Tauri updates. And trying devpod on my nvidia image shows similar behavior. Right now, it just gives Error 71 and fails to open.
DevPod is baked into the -dx images.
Thank you, I appreciate the information and reinforcement that it was part of the nvidia build. I appreciate your time to answer, have a great day!
