When you say you prefer the daemonless approach where did you put the command?
I didn’t input any command (other than command pallet and modals after that).
I simply prefer the deamon-less approach Podman is proposing over Docker
It should be podman if setup as a daemon but I’m guessing it isn’t finding it and defaulting to docker
Podman is deamon-less, yes; When it failed, I tested with “podman
”, now, i’m testing with “docker
” but it’s been more than an hour that the container is downloading parts.
What is your full devcontainer.json?
It’s a new devcontainer (using the universal image) (see bellow)
Did you switch docker-compose to podman-compose?
I didn’t input a single command nor changed anything in Bluefin, I’m quite new to the dx part of Bluefin
I’d used whereis podman
and put the whole directory in there. same for podman-compose
I was used to put “podman
” or “docker
” on Windows and it kinda worked, I think it was what was recommended in some docs I’d seen back then
malix@malix-pc ~> whereis podman
podman: /usr/bin/podman /usr/libexec/podman /usr/share/man/man1/podman.1.gz
malix@malix-pc ~> podman info
host:
arch: amd64
buildahVersion: 1.35.4
cgroupControllers:
- cpu
- io
- memory
- pids
cgroupManager: systemd
cgroupVersion: v2
conmon:
package: conmon-2.1.10-1.fc40.x86_64
path: /usr/bin/conmon
version: 'conmon version 2.1.10, commit: '
cpuUtilization:
idlePercent: 86.62
systemPercent: 4.52
userPercent: 8.86
cpus: 16
databaseBackend: sqlite
distribution:
distribution: fedora
variant: silverblue
version: "40"
eventLogger: journald
freeLocks: 2032
hostname: malix-pc
idMappings:
gidmap:
- container_id: 0
host_id: 1000
- container_id: 1
host_id: 524288
uidmap:
- container_id: 0
host_id: 1000
- container_id: 1
host_id: 524288
kernel: 6.8.10-300.fc40.x86_64
linkmode: dynamic
logDriver: journald
memFree: 257966080
memTotal: 14489669632
networkBackend: netavark
networkBackendInfo:
backend: netavark
dns:
package: aardvark-dns-1.10.0-1.fc40.x86_64
path: /usr/libexec/podman/aardvark-dns
version: aardvark-dns 1.10.0
package: netavark-1.10.3-3.fc40.x86_64
path: /usr/libexec/podman/netavark
version: netavark 1.10.3
ociRuntime:
package: crun-1.15-1.fc40.x86_64
path: /usr/bin/crun
version: |-
crun version 1.15
commit: e6eacaf4034e84185fd8780ac9262bbf57082278
rundir: /run/user/1000/crun
spec: 1.0.0
+SYSTEMD +SELINUX +APPARMOR +CAP +SECCOMP +EBPF +CRIU +LIBKRUN +WASM:wasmedge +YAJL
os: linux
pasta:
executable: /usr/bin/pasta
package: passt-0^20240510.g7288448-1.fc40.x86_64
version: |
pasta 0^20240510.g7288448-1.fc40.x86_64
Copyright Red Hat
GNU General Public License, version 2 or later
<https://www.gnu.org/licenses/old-licenses/gpl-2.0.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
remoteSocket:
exists: false
path: /run/user/1000/podman/podman.sock
security:
apparmorEnabled: false
capabilities: CAP_CHOWN,CAP_DAC_OVERRIDE,CAP_FOWNER,CAP_FSETID,CAP_KILL,CAP_NET_BIND_SERVICE,CAP_SETFCAP,CAP_SETGID,CAP_SETPCAP,CAP_SETUID,CAP_SYS_CHROOT
rootless: true
seccompEnabled: true
seccompProfilePath: /usr/share/containers/seccomp.json
selinuxEnabled: true
serviceIsRemote: false
slirp4netns:
executable: /usr/bin/slirp4netns
package: slirp4netns-1.2.2-2.fc40.x86_64
version: |-
slirp4netns version 1.2.2
commit: 0ee2d87523e906518d34a6b423271e4826f71faf
libslirp: 4.7.0
SLIRP_CONFIG_VERSION_MAX: 4
libseccomp: 2.5.3
swapFree: 8581541888
swapTotal: 8589930496
uptime: 2h 22m 8.00s (Approximately 0.08 days)
variant: ""
plugins:
authorization: null
log:
- k8s-file
- none
- passthrough
- journald
network:
- bridge
- macvlan
- ipvlan
volume:
- local
registries:
search:
- registry.fedoraproject.org
- registry.access.redhat.com
- docker.io
- quay.io
store:
configFile: /var/home/malix/.config/containers/storage.conf
containerStore:
number: 11
paused: 0
running: 3
stopped: 8
graphDriverName: overlay
graphOptions: {}
graphRoot: /var/home/malix/.local/share/containers/storage
graphRootAllocated: 1022844993536
graphRootUsed: 28022247424
graphStatus:
Backing Filesystem: btrfs
Native Overlay Diff: "true"
Supports d_type: "true"
Supports shifting: "false"
Supports volatile: "true"
Using metacopy: "false"
imageCopyTmpDir: /var/tmp
imageStore:
number: 13
runRoot: /run/user/1000/containers
transientStore: false
volumePath: /var/home/malix/.local/share/containers/storage/volumes
version:
APIVersion: 5.0.3
Built: 1715299200
BuiltTime: Fri May 10 02:00:00 2024
GitCommit: ""
GoVersion: go1.22.2
Os: linux
OsArch: linux/amd64
Version: 5.0.3
malix@malix-pc ~ [125]> podman --config
Error: flag needs an argument: --config
I don’t know which argument is required thought
At the bottom of the devcontainer.json file this might also help:
I didn’t think it was needed for a basic universal image
By the way, by the time I wrote this comment, my “docker
” devcontainer finished fine, but in 6263575 ms.
.devcontainer/devcontainer.json
// For format details, see https://aka.ms/devcontainer.json. For config options, see the
// README at: https://github.com/devcontainers/templates/tree/main/src/universal
"name": "Default Linux Universal",
// Or use a Dockerfile or Docker Compose file. More info: https://containers.dev/guide/dockerfile
"image": "mcr.microsoft.com/devcontainers/universal:2-linux"
// Features to add to the dev container. More info: https://containers.dev/features.
// "features": {},
// Use 'forwardPorts' to make a list of ports inside the container available locally.
// "forwardPorts": [],
// Use 'postCreateCommand' to run commands after the container is created.
// "postCreateCommand": "uname -a",
// Configure tool-specific properties.
// "customizations": {},
// Uncomment to connect as root instead. More info: https://aka.ms/dev-containers-non-root.
// "remoteUser": "root"
