Custom Curve (mouse accel software)
Is it possible to make this program work Mouse Acceleration - Advanced Mouse Software.
and alternative - raw accel Raw Accel – Free Download For Windows PC
I use Custom Curve Pro for long time now and this is pretty much only reason why I can’t switch to Bazzite… I need it for my gaming perfomance lol. Please make this work dear developers Bazzite is freaking awesome you guys really made a wonderful and fantastic product. Best wishes
That program specifically? No. Managing input is a very OS specific thing, Raw Accel will likely never be supported.
The best I could find is configuring libinput manually (see here and here) or using leetmouse which I’d recommend using on Arch as it doesn’t seem to be available pre-packaged on Fedora.
In any case, you would want to use x11 instead of Wayland for that, unless something has changed.
