Community Guide: Backup and Restore strategy (S3/Minio)
Considering the cloud native architecture, is it possible I can get some support to fill in the blanks as to how to get Backup & Restore working with a self-hosted minio(s3) setup working.
I am making use of KopiaUI , to backup the home folder to Minio. Considering the flatpak version doesn’t work. I am a bit stuck. Lets suppose I install it in a devbox. What would be the next logical steps to set it up so that I can make use of it.
Apologies in advance if this has been mentioned anywhere, even if someone points me in the right direction I will update this post with the instructions as it becomes clear to me and hopefully serve as a guide for others in the future.
What error do you get when trying to connect the flatpak to minio?
Hi again !
I don’t think its a bluefin issue , or might be ?
under the reviews in flatpak there are 2 comments from this month that the app itself doesn’t work. When you install it in the top right corner the icon shows up and no GUI opens up.
Solution:
I don’t know if its something the developers setup. But its wicked. So when you install say devbox Ubuntu… and if your familiar with installing commands there, you can launch kopia from there… and everything is just mounted in your home directory automagically , and restore from there… So I’m just trying to wrap my head around this but essentially you can run anything in any other OS and your home directory is attached.
I do get all these errors , but regardless of what they do ; I’m syncing my home directory back together and just ignoring these :
[20601:1225/135248.302641:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
Checking for beta autoupdate feature for deb/rpm distributions
Found package-type: deb
Gtk-Message: 13:52:48.776: Failed to load module "canberra-gtk-module"
Gtk-Message: 13:52:48.780: Failed to load module "canberra-gtk-module"
[20601:1225/135248.790371:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[20601:1225/135248.790413:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
13:52:48.817 › failed to load content
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open nvidia-drm: /usr/lib/dri/nvidia-drm_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
13:52:49.319 › failed to load content
[20601:1225/135249.870953:ERROR:cert_verify_proc_builtin.cc(701)] CertVerifyProcBuiltin for 127.0.0.1 failed:
----- Certificate i=0 (O=Kopia) -----
ERROR: No matching issuer found
